- Apr 21, 2015
- 690
Intuitively, I'd also think that a granite surface plate would be terrible for removing a burr after dinging a precision ground surface. My intuition says a granite plate would only be good for burnishing and not for removing a burr.
Yet Starrett sells a granite stone expressly for removing such burrs. Dave also reports success doing the same on a surface plate.
I'm inclined to believe (especially with my humiliating lack of a surface grinder) that a precision ground 2" wide granite parallel might make a passable replacement for a precision ground stone like Robin shows in his video. Robin's stones might work better or faster due to the porosity of an India stone, but a shop grade granite surface plate might actually be cheaper than the commercial $500 stones that Robin mentions (for those of us that can't make our own).
It might take some time and effort with an abrasive stone cutter or chisel, but a $30 surface plate could make a a half dozen or more small hand stones. I'm tempted to try it.
This sounds truly outrageous, but I'm also wondering if a granite plate couldn't also be used as the final step to make a "precision ground" India stone. I want to try flattening an India stone on a diamond plate to get it relatively flat, then lapping it on a granite surface plate directly! I'm probably missing something, but I just don't understand why a stone lapped like that would have a substantially different surface than an India stone ground with a diamond wheel.
This is all just a gedanken experiment for me at this point though. I have no experience at all with any of this.
Rex
Rex
