Bob,
I know this thread is old.
What have your results been like with surface grinding flatstones?
I think Professional Instruments uses an air bearing grinder to grind theirs.
The cheap Shars wheel is now doing a fine job. It was only off about .001" radially when new and had a few striations in the face. I dressed those out pretty easily. The wheel has been if beautiful balance from the beginning. Others who have purchased them have been a lot less happy with what they received. It took about half an hour to dress out the .001" runout and most of the other imperfections. Grinding the first two stones pretty much cleaned up the rest, and has been getting better with use. The wheel needs to be used by plunge cutting the entire wheel face as much as possible to help the final truing of the wheel diameter and face. For getting the stones really flat it helps a lot to use a small step over on the final couple light passes.
A Norton wheel would be a big help out of the gate. It will likely be truer and better in every way. It is just the cost of it... There are additional issues that can come up from the wheel adapter and the grinder spindle that can and will cause problems no matter how good the wheel is.
