Sounds like so much fun! Do you have the factory info for how to do it?
No factory manual. It is a 3500 4 x 4 RAM unit bearing was stuck.
2 days of hammering, penetrating oil, and a 5 lb slide hammer also
48" pipe wrench trying to break the corrosion seal including jumping on the cheater bar on the end ...
air chisel also
Hammer drill and the trick of using the power steering with a 7 inch socket and extension
Plus, finally getting perturbed assembling only the brake components and just the axle nut and then doing an impersonation of Dukes of Hazard or maybe Charles Bronson's 'Mr. Majestyk' in the field. Heh Heh.
Back on the lift and the power steering trick Finally worked at that point a whole can of penetrating oil had been sprayed but the unit bearing is out less than an hour to break the axle shaft down and get the old U joint out one cap was broken and another seized which further complicated removing it from the front arm casting once the unit bearing was off.
I did get to use the lathe again because sockets would not set square on the press because the axle cap holders are not fully square so made a thin wall outer bushing with a an area ground out to square the u joint in the press.
Bought a new unit bearing because it is probably damaged at this point and also made sure to get a spicer U joint instead of a GMB or some other short life U joint. The hits keep coming, Grand daughters Jeep Wrangler blew the radiator and had it towed 50 miles to my garage. Plastic top cracked on it so as soon as my truck is running will tackle radiator replacement. Then back to the TLB the correct bushings have arrived.
OR , maybe finally use the now functional truck to get the boat out of the barn and get out on the Lake - this work seems to much like work lately.
Barbeque idea sounds Good as well. added pic I forgot the porta power
edit:
What did I make in the shop today? A mess. but progress was eventually made. found a pic of last summer
yeah I am going to dig the boat out.
Out the window just now momma deer and her kids eating white clover Actually no complaints.
