Another mini project, wife wanted some feet for the sofa which were hard to find.
Made 10 of them which is kinda nice as you can find a good method and just repeat it.
I'm still such a rookie when it comes to working both ends of a piece, definitely need more practice.
Started with the red tube, faced one end, flipped it around, faced and bored the other end(same tool/op).
This was mostly to get the faces parallel and the tube to the right length.
The bore is for the orange plug/foot so it can't slip further into the tube.
Orange part was cut from flat stock using a hole saw, so I got a bunch of cylinder slightly bigger than needed.
I then drilled a 6mm hole so I could put a bunch of them on an arbor and turn them all down to 23mm, had I thought ahead I could've just used a 6mm center in the hole saw and saved some time there.
After that I could press them into the tube and face the tube again so everything was flush and correct length.
Blue part was then turned from flat stock, cut a whole bunch of 40x40x8mm pieces and drilled a 6mm hole through them which allowed me to put them all on an arbor and turn them down to ~40mm diameter.
After that I turned them one by one to get the smaller diameter and redrill/thread to M8
These were pressed into the tubes and welded.
Felt like it took quite some time but then again it's like 60 different setups to get it all sorted.
