Actually sharpened the tool and it worked quite a lot better. Well enough to let me take about 0.004" cuts and generate some curly chips.You should not have to rough out the slot. Shorten it as you describe. I would check your rake angle. I would suggest trying to get about 5 deg of rake on the end. If you left a 90 deg corner there then you actually have a negative rake angle and will get deflection. What angle do you have?
Edit: I just checked my tool. I have about 5 deg or relief and a minimal positive rake angle, maybe 2 deg. Keep in mind that rake angle is with respect to the direction of motion, not the axis of the cutter which in your case is angled.
Finished slot in new pulley
Now I just have to locate the center of the keyway vertically and drill & tap for the set screw. Some tables I looked at on the web call for 1/4-20 set screw for a 5/8" bore and 3/16" key. That seems big to me - should I go with it?
