Another short-ish post. This time I made a few rods.
The first rods to make were the stainless steel piston rods. I had not yet machined SS. I don't know the grade of SS provided. I do know that is was harder to machine than CRS.
I used my carbide insert tools to turn the small end of the piston rod to the correct diameter and for the correct distance. My first few cuts were "big" at .01. My last few cuts were clearance cuts taken without changing the cross slide position. In between were some .002 cuts. Eventually I got the diameter needed for the 3-48 thread.
Using my carbide insert tool to machine a stainless steel stock for the piston rod.
I then threaded this with a 3-48 threading die and my die holder. I could do this threading under power, because my lathe is powered by a 90V DC motor with variable speed. This aspect of my lathe is really handy when I have to make a lot of male threaded parts.
Threading the small end of the piston rod 3-48.
Once the small end was done, the other end was simple threaded using my 5-40 die; no turning was necessary.
The finished piston rods.
The eccentric rods (valve drive rods, valve movers and shakers, etc.) come as brass round stock that requires splitting in two, a bit of shortening, and then threading.
The finished eccentric rods (valve push rods).
The last bit for now is making a bunch of nuts. The kit provides 3/16" and 1/4" brass hex stock. The nuts are made from the 3/16" hex stock, the 1/4" stock is used for the gland nuts (not done yet). Two of the nuts are 3-48 and the rest are 5-40. So, two nuts worth of hex stock were drilled for a 3-48 tap, tapped, and then cut off to the correct size. Before cutting of my nuts, I would chamfer the exposed side. The rest were were treated likewise but for 5-40 threads.
After I cut off my nuts, I had to clean up the burr left over from the cut off operation. To do this, I mounted each nut back in the three jaw chuck and used a sharp lathe tool to trim off the burr. Then I used a small file to chamfer the edge. Or, I would forget to do the chamfer, remove it from the chuck, realize my mistake, remount it in the chuck and then chamfer the edge. And then realize that I did not remember to chamfer the other side prior to cutting it off from the hex stock, and ......
De-burring my nuts using a very sharp HSS tool bit.
The slowest and most painful part of the process was getting my small nuts into the chuck with my over-sized hands. Otherwise, this all went quite smoothly.
Until next time.
Cheers,
Tom
