- Jan 24, 2015
- 239
A quick note: I realize I am putting in a lot of detail in the text. For those who want to skip this detail, I am now including captions on the photos. The captions are in a different font to help distinguish them from the main text.
Next up is the flywheel. This one was pretty simple, though my explanation below may not be.
The raw casting. It is bronze.
Because I don't know flywheel terms, nor can I find them on the web, I am going to use the terms as indicated below. Hopefully that will help things remain somewhat clearer than mud.
What I call the parts of the flywheel
I started by chucking it in the three jaw chuck from one side. I spent quite a bit of time getting it set up so the hub rotated close to the center by trying different angular positions until I was satisfied.
The flywheel freshly chucked up in the lathe
Since there is a casting draft on all surfaces, I did not feel this was the most secure arrangement. Therefore, I took some very light cuts on the inner rim at a slow speed and feed until that surface was clean.
Making very careful cuts on the inner rim to create a better clamping surface for the chuck.
I then flipped the wheel over and re-chucked on the newly cleaned up side. I then cleaned up the inner rim, the rim side, and the sides and face of the hub. I cleaned up the the outside rim of the wheel using the Sherline compound set at whatever angle was called for (I think 5°). I made sure to cut deeply enough to go over the centerline, and and then I carefully noted the final depth of cut. This way by cutting to the same depth on the other side I could be reasonably sure to have apex of the wheel centered side to side.
Cleaning up the surfaces of the flywheel rim
Cutting the outer rim taper using the Sherline compound. This compound mounts on the back of the cross slide and the tool is mounted upside down.
The hub center drilled, drilled and reamed to 1/4".
Center drilling the hub.
I then finished facing the rim side until that was nice and clean with a nice clean meeting line to the outer rim. I recorded the distance from the spoke base to the edge of the rim (the rim inside depth).
The wheel was then flipped again, the rim side faced to create a rim inside depth that matched the other side. The outer rim on this side was cleaned up using the compound as previously described.
Then it was over to the mill to drill the hole for the hub grub screw. I mounted the three jaw chuck, with the flywheel still in it, to my angle plate. I used the crankshaft to center the flywheel hub hole under the spindle. Using the long center drill, I spotted the hole, and then drilled it out and tapped it. Pretty slick, really.
Indicating the spindle on the center of the crankshaft to find the center of hub.
Center drilling the hub for the grub screw hole. This was followed by drilling and 5-40 tapping.
Progress so far:
Progress so far:
