- Nov 25, 2015
- 9,421
and collect all the swarfCan you drop a magnet in the can so it will stick to the machine bed making it seem to have a heavy base.
win winand collect all the swarf
I meant on the bottom of the outside of the can, not inside. It's a gun, so nothing will get inside like a brush. Then you won't be able to put it down level, and will have to pull the stuff off to sit it down.win win
Who said the inside? I would use another one if I was machining ferrous material. It does not have to exactly level.I meant on the bottom of the outside of the can, not inside. It's a gun, so nothing will get inside like a brush. Then you won't be able to put it down level, and will have to pull the stuff off to sit it down.
My plews seals over the ball oilers nicely, but so nice that it won't pump any in. The ball blocks it. I put a notch in the end of the spigot, but that did not help. So I was over it. Don't know why it won't pump in a ball oiler.. But all my other oilers do.Bought a Goldenrod and before any oil was put in, it got an alcohol rinse and the bottom crimp was carefully and neatly resealed with RTV. Many comments about the new ones leaking, so got in front of that issue whilst adhesion was still on the menu.
The tip was not very conducive to getting oil into the ball oilers. A short length of soft clear tubing over the tip fixed that issue nicely. Trimmed clean and square with a razor blade, the tubing pushes and seals around the ball and oil goes into the oiler with little or no mess/wasted oil.
Later the trigger started sticking, so out came the pump assembly and had to fettle the components to mate as they should. With that, my little oiler actually works very well - and continues to.....so far. Just over $10 on Zoro last time I looked.
Gravitywell, it's brass, you can't stick it, you would need to glue it to the bottom.
And .. I give up... forget it.
