- Jul 28, 2017
- 2,593
As a young engineering student in a very unruly college dormitory I devised a tennis ball cannon. It was driven by the rapid combustion of warm alcohol vapor in a tube formed by several (steel) beer cans, tops and bottoms removed -- except for the bottom one. I discovered that tennis balls were a pretty good fit to the ID of the commonly-available beer cans at the time. The tops and bottoms of the cans were removed, then they were duct-taped mouth-to-mouth. Except for the bottom can, which was the combustion chamber -- its top was left more intact to act as the rest for the tennis ball. Firing the thing off through a touch-hole heated up the combustion chamber a bit, but it wasn't all that much.A friend with a CNC shop had a coolant spill. The cleanup kid vacuumed it up with the shop vac, bud didn't bother to empty it. Several days later someole turned on the shop vac. The sparks from the motor ignited the methane produced by the coolant and blew the top off the vacuum. It made a large dent in the metal roof 20' over head.
Let's be careful out there.
In the dorm it became a "thing" that escalated like some arms wars we have seen. The last one I made shot a tennis ball a couple hundred feet with little drop in elevation. That was the end of that, at least for me!
Overall, the most fun was emptying the beer cans to make the cannon.
Since then I've thought we were very lucky to have not suffered any injuries. Getting older does (hopefully) impart some wisdom.
