i was able to adjust the clutch easily. I just used a pin in one of the adjustment holes on the ring nut after loosening. I just rotated the pulley and used the linkage bar to stop the pin. rotated about an 1/8th of a turn as manual states. Also tried out the range on the hydraulic speed control. This lathe does not have a round cy;inder, but the hole block moves into the suare manifold. I took a fewe videos of the speed testing and clutch engagement and stopping. It gets noticibly noisy at lower rpms ??? I believe i need to adjust the motor belt connecting the bottom sheave of the hydraulic drive.I did not use that blue level to level the lathe. I did use a precision level +/-.0002 per 10" to level.
