- Mar 16, 2017
- 149
I used the ArizonaCNC conversion kit for the PM-940. I was very impressed with the kit. Everything fit perfectly and it was easy to install. The fit was impressive considering the Chinese casting are somewhat rough. I had to put a small shim on the Y Axis ball nut holder where it mounted to the saddle as the casting was slightly off, but that was the extent of my adjustments. I had a few other minor glitches that were my fault, such as accidently running the ball nut off the ball screw which allowed me to learn how to pack the balls into a ball nut. It is actually quite easy. In addition to a great fit, Dave at ArizonaCNC provides great support for his product. As I knew very little about Ball screws and CNC machines, I had a number of questions and he talked me through everything. I highly recommend his products.
I used Clearpath servos and they mounted up to the ball screw mounts perfectly. Clearpath has a servo tuning program that runs on a PC that is used to test and tune the servos. After a little tweaking of the gibs and adjusting the servo mounts to ensure that everything was straight, the tuning program ran nicely and show that nothing was binding.
This picture shows the Z axis mount and servo.
