- Mar 16, 2017
- 149
I think you are right Mark, although the fan does not show up on the wiring diagram. Below are pictures of the motor, motor plate and the 2nd connection.
I have finally figured out the wiring diagram, however there is one component I don't understand. There is are 2 devices called "H3Y" that seem to be a time delay relays that are in the FWD/REV circuits and seem to add about a .5 second delay in the FWD and REV connections to the VFD. I'm not sure why these are needed. Maybe someone has seen this before and know why they are needed. The wiring diagram is below. The components in question at KT1 and KT2. For some reason they are installed in different locations on the FWD and REV circuits but look like they have the same effect. This is the diagram that comes with the machine from China, not a PM updated diagram.
On another note, I am moving along with the disassembly. I haven't decided whether I will repaint it or not. After I get it all cleaned up I'll make that decision. It shouldn't be too hard as there are only about 7 parts. The hardest thing to take off is the box with all the electronics. This requires removing the panel where everything is mounted to get to the screws. I'm not sure this can be done without disconnecting wires inside the box and I don't really want to do that unless I decide to remove it all and control everything via the Acorn board.
