- Oct 11, 2016
- 4,014
@D.sebens your work looks small enough to do on the mill without a rotary table. put them all together, insert a 1/2" pin through the centre, and put it in the milling chuck with the centre pin on top of the jaws. It helps to tack them together with a welder first, to make the milling easier.
Make successuve cuts across the work, rotating the work in the vise and reclamping. I can cut this 1.5" radius in soft steel 1" deep in about 10 minutes this way. No setup time.
