- Nov 25, 2015
- 9,838
so you should start on the right side of your part so you are conventional milling. I use a sacrificial piece of AL or many times just a piece of thin wood (thin ply, thin paneling ) so I can cut through without damaging the table. Start the roughing further out and move in using light passes.So then for setting up the operation for the radius, do I start from 0,0 and move over to the side of the of the part and radius 180*?
your initial passes won't come close to the sides of the piece. It's when you get close to size.
