That would seriously interfere with my lighting.
Lighting would be easy enough to move.That would seriously interfere with my lighting.
I don't want to move the lighting. It's exactly where I need it. This thread isn't about my lathe anyway. The eyelet drops between the lights into the corner of the table and y axis. It's pretty much spot on where I need it.Lighting would be easy enough to move.
Oh man lathe envy
I need the light to see.I moved 2 hanging 4-foot florescent lights to install the Unistrut. so worth it.
what I want is the Star Trek transporter to materialize my accessories where they need to be, and store them in the buffer when not in use
Another way to consider is to install a length of unistrut, and use a unistrut trolley which rides inside the unistrut channel
That way you have ability to overhead roll whatever you are lifting to another area..
Hi, I like your idea, where did you get the small cart? Thank you!I knew there would be the day where I wouldn't be able to lift some of my accessories easily. I'm not old yet but with a semi bad back & arthritis starting to kick in, that time is coming sooner than I thought. And I only have small hobby size stuff.
Here's my planned solution, I got this years ago before I actually needed it. I still don't use it much now but I probably should.
Those furniture dollies are great, I keep multiple on hand for all sorts of uses.
View attachment 500992View attachment 500993
