- Nov 13, 2013
- 140
Depends on the equipment you have. I would cut a slot with an endmill. Otherwise, I would put a blob of weld on the steel part and punch a hole with and endmill. No need to make a plug for such a small hole. Use a chunk of aluminum or copper to cover the back of the hole while you're welding. Honestly, I'm having trouble imagining the situation you are trying to solve. If you could add any details...
Aligned and "tig'd" a 0.25" washer where I wanted the hole to be then milled through the washer using a 0.25" endmill.
A broken endmill was inserted through the holes to confirm proper alignment.
How to best fill the void? I'm not the best welder...............
Will a 1/4" aluminum pin inserted in the hole allow me to fill the void with steel tig rod?
You guys bailed me out again. Thank you
