I usually do about the same thing Mikey does. 36 ceramic to shape, then a 80 or 120 AO, quick touch to get most of the marks, then hone with 3 grades of diamond cards.
Watch the angles when you switch belts or reposition, dip in water, etc.. It's easy to make the tool look like you're cutting a gemstone. I find it helps to line up and firmly press into the platen. It's more about practice than anything else. And HSS being harder to grind helps a little there.
I have belts to 800 I believe, but I bought them for polishing knife blades, not tool making. I tried it once, but it wasn't really useful. The time spent swapping didn't save enough time honing for tools. One of these days I should make a knife...
