- Jan 2, 2014
- 9,487
Once you cut a piece out of it, the grinder will become usable for tool grinding but it also makes it less usable for grinding other stuff because you'll have a part of the belt without any support under it.
A small notch (like the one I cut on mine at the link I provided above) does not compromise using the sander for other functions.
There is no unsupported part of the sanding belt.
For mine the notch is near one edge. I typically keep the belt centred, and only move it over to the edge of the notch when grinding lathe tools.
The belt tracking adjustment (that simply tilts the upper roller) is enough to do that.
How long do you think the platen would last? A month of moderate use? More? Less?
I have had my old sander with a steel platen for around 15 years.
I use it heavily for wood, aluminum and steel.
I cut the notch in the side over two years ago (by the date on that other thread).
There is NO divot sanded into the steel platen.
If it died today, I would buy a smiliar one tomorrow......and cut the same notch, but maybe faster with a hand-held angle grinder.
-brino
