It looks like your sander already has a couple holes you could use for a better table mount:
Those are the threaded holes for the back side belt guard.
But I suppose they could be incorporated into a tool rest as well with a little thought.
Thanks for the idea!!
I was thinking along the lines of making a riser for the existing table to raise it for 90*work.
After I made that last post I discovered that when the rest is tilted for grinding say, the 15* angles, the side nearest the belt raises enough so the tool/belt presses against the platen.
It also does not have a miter slide although the table has a 5/8" slot for one, to narrow for the 3/4"slide from my Craftsman table saw. So making one of those, soon as my mill is up and running (hopefully tomorrow) is at the top of my to-do list. I have another that I can modify for that use but it will have to be narrowed on each side to fit the slot as well.
Can one of you folks suggest a decent tool for checking the angles on these bits while grinding them?
Was thinking of a square head protractor but many of the reviews on Amazon are not the best.
This $5 e-bay find showed up in the mail this morning w/free shipping!!
