I use 1/2" shank carbide router bits in my mill with pretty good results.
I don't do lengthy wood projects on my mill. I clean all the metal chips before cutting wood and cover as much as I can. Then, give it a good vacuuming after the cuts.
This is an access hole I cut in some 3/4" Baltic birch plywood for a keyboard controller stand to access the plugs and switch.
Two 1" starting holes on the drill press with a forstner bit, then cut out between them with a 1/2" straight router bit on the mill after hogging it out with a 7/8" forstner bit.
