So I started on the new connecting rod but only got as far as facing the two sides. The next step is to drill and tap the bolt holes, then split the cap with a slitting saw. Since this requires flipping my mill head 90 degrees to the side, I opted to work on some other parts first.
The eccentric ring is the next big part needing to be done. I started with some hand filing to clean up the exterior flash then milled the two faces to size. I had the part sitting firmly on the parallels in the vise but still ended up with 0.003" of non-parallelism in the opposing faces so I think I need to inspect my parallels and vise to see if something is up. Thankfully this shouldn't affect function and I can always scrape flat if needed.
I didn't get pictures, but in a second setup, I faced the top of the bridge, drilled the connecting hole and oil hole, and drilled, tapped, clearance drilled, and spot faced the holes for the bolts which will hold the two halves together after slitting.
Next I tried out my new Tormach Slitting saw arbor for the first time on scrap aluminum and steel. The blade is 1/16" thick, 3" diameter, 30 tooth and is dish ground.
I got a full 3/4" depth into mild steel using a 1/2" pass followed by a 1/4" pass. The blade has some radial runout but nearly zero axial. The tormach holder is very nice and I suspect the blade itself has runout.
The part was indicated flat using a 0.0005" DTI on the spot faces and then the indicator was zeroed on one spotface.
The blade height was adjusted to zero on the indicator such that the top face of the blade was level with the spotface. The DRO was then set at 1/2 of the blade thickness below zero.
The slitting saw had no issue with the cast iron.
Here is the clearance I was working with.
And split.
A quick file stroke removed the bung of material left by the saw on the top piece.
And the 2 halves lined up perfectly.
Next operation is to bore the precision hole for the eccentric.
I read so many horror stories about slitting saws, but found this to go extremely well.
More to come - Mike
