There are several chuck rebuilding services out there. Most only service big or automatic chucks. I am looking for one that might hold (or manufacture) some spare parts for old Buck chucks. I have a little 5 inch three jaw chuck that fits my 1953 Logan 10" lathe. The chuck was manufactured in August of 1953 and is marked "Logan 436". Logan has informed me that most of the chucks they supplied with their machines in '53 were made by Buck. Logan did not offer any alternative manufacturers.
This chuck is in very good shape with the exception of the little pinion that turns the back of the scroll. Someone got brutal with the chuck key at some time and the teeth on the pinion are "bent". The jaws fit very well but the "outside" jaws were missing when I got the lathe. The scroll itself looks very nice and the "ring" gear at the rear of the scroll shows a tiny bit of wear, but I think that the pinion is the main problem.
If anyone knows a chuck re-builder. Or I can search ebay, etc. for the parts or consider the difficult process of making another pinion. This little gear is heat treated and is a beveled pattern. Has anyone tried making something like this. I would still need a set of outside jaws to have a first class chuck.
Guess I'm searching for some advice on the direction to go.
Cheers, Geoff Morgan
