- Nov 6, 2012
- 152
On a Southbend, I had first turned the breach end of the cannon, reversed and clamped in a sleeve, then turned the muzzle, then drilled and bored the bore last.@GeneT45
I have had absolutely ZERO grabbing since I started using ally inserts on brass. The edge is sharp and cuts nicely. CCMT/CNMT always seem to want to grab when I use them, even when on centre.
The WD40? it keeps things cooler and further lessens potential for grabbing.
@MaverickNH
Have you determined your order of operations yet?
Will you be turning the bore first? if so, you will need a fixed steady rest and once bored, you could, indeed, consider @Charles scozzari option of a plug in the bore to centre on with a live tailstock centre.
Pictured here https://www.hobby-machinist.com/threads/brass-mini-cannon-first-firing.114139/
