- Jul 26, 2011
- 4,139
The gap fitting back into place has nothing to do with how many tools you have on hand. As I mentioned,the gap block on the 16"lathe we had at work sprung UPWARDS a bit when removed,and simply would not quite blend back into the ways when replaced.
I have been using lathes since 1959,and I can tell you it is just a GAMBLE on Asian made lathes as to if the gap piece WILL go back perfectly after removed. The cast iron may not be perfectly seasoned. Or it may have developed stress when machined,INDUCTION HARDENED and ground in situ. They don't check those things in Asian lathes at the factory. The lathe at work had about a .015" misalignment when replaced. The front way on the gap block was about .015" TOO HIGH . I'd say the gap block cupped a bit INWARDS when removed,causing the front way to be too high. So,not caused by loose debris under the gap at the factory. It would have been MUCH easier to deal with had the gap gone back in a bit LOW! Possibly,I could have solved the problem by drilling and tapping extra bolts in the gap block,close to the edges,to draw it back down to level.
The same model,I have at home,fortunately went back perfectly. I won't say I was afraid when I removed it,after having the problem with the identical lathe at work. I WAS concerned,though. I knew it was a gamble. I had had the lathe since 1986 without a job coming along that required removal of the gap block. This was about in 2014.
Fortunately,we got a new,larger lathe at work before I got to dealing with the gap piece. No budget at home for a new lathe,though!
If there is stress in the gap block,it will not quite fit back when replaced. It can be a real PAIN to try re machining it,too. I can handle it,but many may not be able to. It can be a complicated item to deal with.
