Cooling water tank is next and I had a nice piece of 2.5" aluminum round set out for just that. After some thought I put that piece back in the drawer and found a cutoff about 1.25" thick and a piece of aluminum tubing. Now I can taper the inside of the cutoff and then press it into the tubing and then taper the outside.
Much easier than working down inside the tube and I used up some cutoffs.
These are the parts that make up the tank. The center tube extends up to within 3/4" of the top of the tank and that will channel the hotter water to rise to the top of the tank. The cooler water will fall to the bottom of the tank and back to the engine via a copper pipe.
That is what it is supposed to do.
Tank installed.
And a view down inside the tank.
Didn't get a picture of the other side of the engine but I will later.
As promised this is the other side of the engine showing the cooling water return line.
This little part took quite some time to make. It is the bracket that holds the hall sensor. I wanted it to be adjustable so the curve matches the OD of the flywheel. I installed a magnet in the outer rim of the flywheel to activate the sensor.
