The gas tank is glued up and ready for use.
Cutting out the gas tank support.
Right off the mill.
Drilled some mounting holes, cut a slot, and one hole for the clamp.
Gave it a little polish and here they are installed with the remote fuel needle.
Next will be the throttle.
Thanks for looking
Ray
I have an idea that may work and not drastically change the appearance or the spirit of the engine.Yes, the exhaust valve sealing is tricky.
I have a CNC mill that I built several years back. It is very handy for one offs but I still prefer my manual mill for most things,Have you a CNC mill, or did you cut that out on a manual mill?
