Are you done yet? Are you done yet? Are you done yet? Been retired 2 years now and still raises my blood pressure. When I was young it was "It has to be done right" now it's "It has to ship Friday"Production schedules, got to meet those production schedules.
Oh for shops that require management to work on the floor during their trial period . . . I was very fortunate in the time I worked on aircraft. Management had either done it or managed it for long enough to known what was normal inspection and repair as needed and the time needed for a job, or a mess and it will take what it takes.Are you done yet? Are you done yet? Are you done yet? Been retired 2 years now and still raises my blood pressure. When I was young it was "It has to be done right" now it's "It has to ship Friday"
I bet 4 - 10 layers of heat shrink will fix it right up. <smile>LOL okay what's wrong with this picture...yes that cord grip on the right is gripping nothing but thin air . It's way too large for that small cable and the cable moves freely in/out. I'll have to order up a new cord grip.
Exactly. I saved about $2k going with the Grizzly lathe vs similar lathes from other companies. While that means I'm likely to have to deal with some quality issues like this batch of annoying but minor issues in this thread, in return I have the $2k saved for upgrades. The made in USA Baldor motor. Higher end DRO. Dorian QCTP and tool holders etc.You got a lot of lathe for the price...I knew when I bought it that it was built to a price point. It has exceeded my expectations.
Installing the proper size cord grip will take no more than 5 minutes, there's only 3 wires to unscrew. It's not a strain relief in this application it's a cord 'grip'. To prevent hooking the cord on something and ripping the wires loose inside the electrical cabinet. Highly unlikely that will happen here but there's no reason to leave it half assed.The purpose of the strain reliefs is probably more to protect the cable from the metal box, not to provide a strain relief or resistance to fluids. There is nothing in the lower holes that the cables go through. Rather than mess with pulling cables and rep;acing the strain reliefs, slit a small piece of rubber tubing, slide over the cable and up into the gland and tighten. Only reason to have a functioning strain relief is if someone is pulling off the control cabinet and not disconnecting the cables, Oh forgot that is what you are doing. Not how I do my electrical cabinet builds, as I size the gland to be able to provide some resistance to cable pullout.
I have had an 8X12 Harbor Freight lathe for several years now. I've fixed/improved several things and honestly I like it. However, this little quality control oversight tends to bother me the most.You got a lot of lathe for the price. But it was built to meet that price. Hopefully the parts that really matter are built to sufficient levels to do what is needed. I have a Chinese lathe, PM1440HD. It had some things that were sloppy in design and or execution. Most I got fixed the rest didn't matter all that much. It has run fine for 8 years. I seeps oil because of a poorly designed gasket surfaces. Same dumb design as British motor cycles.
