Okay, it's hard to believe that I started this thread about four years ago.......and the V2 EDM machine is still NOT DONE!!!!
I have NOT built or bought a dedicated power supply for it
I have NOT hardwired the circuit around the arduino controller
I have NOT played with the high-voltage supplies
I have NOT added a bank of spark capacitors that are easily switch in/out
I have NOT put all the above in a case
I did just use it though....and the sketch here in post #37 came in real handy when setting it back up.
Once I literally blew the dust off the arduino circuit in the "bin board" it worked great!
I picked up these partially built lathe tool holders at the local used tool place for $10.
The one with the red X's already has the dovetail cut too big for my tool post.
The nearest one has the tap broken off in the right-most hole.....
My guess is that's when the builder gave up and sold all his tools!
(we all know the feeling, right?)
I thought I'd let the EDM work on it while I did something else....(I still don't have end-of-stroke limit switches installed either)
Here it is being lined up in the vise:
...and a short video clip of it running:
View attachment short_clip.mp4
After a few hours and one electrode change, the broken tap was just about cut thru and I picked out the bits with tweezers.
The cylinder in the middle is the centre of the tap, and around it are the tap flutes:
You can see how the brass tube electrode got eroded too and became form-fit to the tap flutes.....
It did work, but I think the copper electrodes lasted longer and cut faster.
Too bad as I now have a small bundle; brass was recommended in one of the books, and I had been picking up pieces when I saw it.
Oh well. It will get used somewhere.
Here's how the threaded hole turned out (I have not yet run a wire brush and tap thru it...):
At this rate I should have the project complete sometime within the next 30 years or so.....
-brino
