- Jan 2, 2014
- 9,606
okay, it's waaaaay past time that I updated this thread.
The pump and filtration system is working great (even if I couldn't find a way to incorporate magnets!).
After a number of test cuts I could see the water flow slowing down, so I took the filter to the laundry sink and ran water thru backwards and it immediately restored the good flow.
What have I cut?
After adding a diagonal brace to stop the EDM head from swinging around I cut a new thru hole in that same 1/4" thick scrap steel bar using the same copper tube electrode.
I must not have dried it off after removal from the tank....it got kinda rusty.
However, it showed: i) the hole was much more round as the head did not bounce around, ii) the new nugget is cylindrical (the first one was a cone from the head swing).
still more to come.......some spoilers........I tried a brass tube instead of a copper tube electrode, I have tried reverse polarity, and I tried a pencil "lead" electrode.......and more
-brino
What have I cut?
-brino
