- Oct 16, 2024
- 8
I recently bought a Craftsman/Atlas lathe with a 1hp Baldor dual voltage motor on it. It had a 110v plug on it when I bought it. After finally being able to read the data tag I was able to confirm it was dual voltage. Since all the equipment in my shop runs n 220v I thought I would convert it also After lots of searching I thought I had found a diagram that was correct. But when I started it on 220v it growls and vibrates . It is an older motor so I'm not sure if I have it wired right or not. It does run fine on 110v. I have searched the net but not found anything with this problem. Any help??
