- May 3, 2017
- 2,039
Happy to report: Success on the installation!
Given this was my first attempt at installing a DRO, I'm sure I wasted a lot of time designing, measuring, fabricating, re-measuring, re-designing, etc. Probably a little overkill on the adage, 'measure twice, cut once', but in the grand scheme of things, I'm glad I did. I made a couple of design changes in the process that are vast improvements over my initial ideas. Finished wiring the unit into the lathe about an hour ago, and just thrilled that everything works as it should.
One mishap: While troubleshooting the wiring, I managed to knock the monitor off the lathe and onto the concrete floor. I'm now the proud owner of a one-of-a-kind monitor with a slight, unobtrusive chip on the plastic casing in the upper right corner. (Eat your hearts out.) But look at the bright side. I can attest to the tolerance level on a crash test. And I am emancipated from the bondage of worrying about that first scratch or ding. Life is good.
No pictures yet. Need to clean my shop first.
And a special thanks to all those who loaded this thread with wise counsel, sage advice, and helpful opinions:
Dan, thanks for guidance in ordering. Hadn't heard from you in awhile. Hope your installation is going smoothly.
Bob, thanks for the recommendation. It's a good choice, and I'd buy it again in a heartbeat.
mksj, as always, your observations and technical recommendations are invaluable.
Only thing left is to butcher a little metal.
Regards to all,
Terry
Regards to all,
Terry
