Down And Dirty Bench Grinder Build!
seagiant
Apr 28, 2018
93
Hi,
Picked up a FB Buy, Craftsman Block Grinder for $25...
Decided to make a Lathe Tool Sharpening Station for my Machine and Wood Lathe tools.
Rebuilt the Grinder with new Bearings, and then made some Rests from Scrap Steel I had, not in the best shape but usable.
Nothing fancy but works great and I can set the exact angle I want now.
Have a Green Wheel for Carbide and an AO Wheel for HSS..
Worth the effort and should of been done sooner!
That's almost identical to the only grinding table I ever made (I made just one and switched it side-to-side as needed. Mine was basically training wheels. The angle fixture was the first thing to go, then the table itself. I grind by eye/hand now.
GsT
GsT
Hi,
Yes, some operations the angle slide is not needed or even in the way but easily removed.
I see no downside to this and even more Rest Tables could be made to widen the use of the Grinder.
Hi,
No, there's no downside at all. I just found, after a lot of use, that I didn't need it. It sort of trained me on the angles (in a general sense, I'm not pretending that I hold a perfect 10* (for example) when I'm grinding - but I hold close enough. My incentive was probably in part because I had to move my table to use the other wheel. Being lazy, that meant that eventually I was roughing out on the table (course wheel) and finishing freehand (on the finer wheel). Ultimately I found that I could do either without the table and that eliminated a few steps, strictly as a convenience. There's no quality difference in the cutters, and if I looked in my cutter drawer I would be hard pressed to tell you which ones I ground with the table, and which I ground without.
GsT
Hi,
I have always free hand ground myself but wanted to try by the book to get the correct angles and see the difference.
Here is a Vid I found and this Guy made an interesting Gauge to get or check angles on Lathe Tool bits.
