Yes, the same slitting saw (0.030 thick)
You can see the sequence of cuts on the picture on the previous post.
The tooth profile was defined in cuts 1 and 2. Cuts 3 to 6 removed all the material between teeth. For these cuts, the saw was kept at the same position, pointing to the center of the wheel so the root is concentric. Actually it is formed by six short straight lines (the face end of the saw - kerf).
For each sequence, set the height of the saw (mill head Z) for the offset and the mill table Y axis for the depth of cut.
Cut 30 times turning the rotary table by 12 degrees. New start position (angle), new Z, new Y and cut again 30 times...
It would be much harder without a DRO. And my rotary table is microcomputer controlled. Even so, this was 180 cuts in total. The wrists are sore...
