I will give it a try. a couple posts back you said ware to hookup the start and run caps if you dont mind could you double check as I think mine are backwards. Thanks Mark I really appriciate the help.
Well it made a hum and blew the inline fuse when I put in reverse . Sounded like it would in forward as well. ( I turned if off really fast ) I will double check the wiring again to make sure I did it correctly.
