As I mentioned to
@woodchucker above, I purchased a mag drill to drill the beams. At 40 ft long, no way to maneuver them into a drill press
First time I've used a mag drill or annular cutters. This certainly made easy work of drilling these 11/16" holes. One lesson I quickly learned, pecking with annular cutters doesn't work, as the chips lodge under the cutter in the circular grove. Better to just keep drilling steadily.
The mag drill, a Fein JHM shortslugger, has a small tank on the far side with a coolant feed down the inside of the cutter. A spring loaded pin, sort of like a tap follower, helps center the cutter. This drill has a "safety" feature that doesn't allow the motor to be turned on unless it is on at least 3/8" plate. These beams were not of sufficient thickness (W10x12), although the magnet held well enough. They include a jumper that you can place on the internal circuit board to bypass this safety feature. Would seem to me that a lower threshold would make more sense, as the safety feature would shut the drill off if it comes off the beam. Makes me wonder if it is more of a feature meant to reduce their liability?
