Rabler & Dabbler, I totally respect and understand your position on Aukai's question. However, It brings up the question; any advice given here, in many cases could be potentially dangerous if wrong or misinterpreted.
Sure. Those of us who do a lot of lifting are extra squeemish about giving advice on only a small part of the whole system. But that is not quite what the problem is.
For a given I beam, say a steel beam 4" X 4" wide flange I beam, one can calculate the maximum allowable load in the center, for a point load. - But the reverse question has too many variables: is it a fixed beam, or does it have traveling loads, is is supported only at the ends, or does it have other supports, and a myriad of other possibilities, including how heavy the motor is (as
@rabler said).
I know that *my* 4" X4" I beam can take 200kg at 15 feet, because I calculated all the stresses - for that beam - then I bought the beam and tested it to see that it was right.
For a hobbyist the best approach is to overbuild, but since I don't know enough about
@Aukai question I cannot even begin to answer it. What looks like a simple question might have more behind it than you might think.
I guess that goes for other machining advice, but I think less so.on
