A few years back, I made a giant crane for lifting milling machine and lathe. The only issue with it is that it was a giant.
I am thinking of making another one. The 2 ton engine cranes we often see have the two legs narrowed, and pointing outward. That is not a good foot print for fitting into a milling machine or even a lathe. I was wondering why not having it wider, but more parallel. Would that cause issue?
It turns out there are those:
Get your Hein-Werner 3 Ton Engine hoist from Redlinestands.com today and enjoy FREE SHIPPING!
www.redlinestands.com
Are you searching for the Best Folding Engine Crane for Sale Online? Say no more! Order your Norco 2,500 lbs. Folding Engine Crane and get to transporting your engines today!
However, for convenience, I am thinking of taking an existing crane such as from Harborfreight, and extends making it 1 foot taller, and 1 to 2 feet wider. This probably helps with the weight in regard that the boom does not need to extend far (and up), which makes it somewhat weaker (but mathematically, it's the same, since the torque is calculated on horizontally). Just longer means the more of the extension (smaller/weaker), and amplify the looseness between them.
Anyone has done this before? It seems to be very quick and simple modification (cut out, weld back a foot of steel).
I am sure safety would be a valid concern, but hope we don't just blanket it as unsafe.
