- Nov 25, 2015
- 8,765
Is that video appropriate for this site?
It is not hatred. hate requires emotion, which I refuse to waste on anything that does not deserve it.sorry, but I don't share your hatred for 3 in 1. it's base is mineral oil. It's a decent light weight oil.
Hello! I just purchased my first lathe, an EMCO C8, and am getting everything cleaned up and organized. It was rust free for the most part, but some of the tooling, etc. had some rust here and there. I've removed that with Evaporust and not knowing otherwise, shot the parts with a light coat of WD-40 to keep them from flashing rust until I know what to coat them with. Should I just use way oil for that? I see there is a lot of debate on the use of grease on chuck internals - I'm really asking about rust prevention moreso on those as well as centers, tooling, etc. Any suggestions?
I don't know? But I added a content warning...Is that video appropriate for this site?
As much as I disagree with its objective, The context was spot on for the intended purpose of getting his point across... Its just a movie clip.Is that video appropriate for this site?
Now if that was a clip from the most recent presidential debate which I turned off, then I'd be concerned about offensive content..
My perspective on the 3 in 1 oil issue per the OP dilemma is, while regular 3 in 1 has its place, their are newer and better products on the market designed to specifically prevent machine tool rust... what he chooses and the frequency of application is really dependent on the environment its being used and stored in...
Ed
Try it, it doesn't stink bad, it's a smell that brought me back to my childhood. I used to smell that on something, I can't remember what, but it's not that bad. I kind of like it now.Welp. This was certainly entertaining! Thanks for all the banter and ideas. I ordered some T-9 and also picked up some Fluid Film at Home Depot today. I don't love the thought of using something that stinks, so I'll start with he T-9 and go from there. Thanks guys!
Now if that was a clip from the most recent presidential debate which I turned off, then I'd be concerned about offensive content..![]()
You sure it was not a vehicle of some form that used a rust preventative either from factory or as an aftermarket application?Try it, it doesn't stink bad, it's a smell that brought me back to my childhood. I used to smell that on something, I can't remember what, but it's not that bad. I kind of like it now.
