Hi, it's nice to meet you all.
I wanted to put up a thread on a project I've recently started. I live in the middle of nowhere - well, not quite the middle of nowhere, but you can see it from here - in northern Alberta and so I haven't been spoiled for choice in terms of used machine tools I can find in my area. I ended up with a 1940 South Bend model 9C, which (in addition to no quick-change gearbox, power cross-feed, or threading dial) means plain bearings for the spindle! My hope is to give it a thorough cleaning and fixing-up, and have it as my 'daily driver' lathe as I get myself started in hobby machining.
Overall, it looks like the machine was not too heavily used but also not terribly well-cared-for. Here's a photo from the listing, before I got my hands on it:
The cross-slide and compound nuts seem good, with no slop, and the spindle bearings look okay so far. The only really noticeable issue is that the ways are pretty heavily dinged-up near the headstock; I have vague plans of acquiring some precision-ground flat stones and stoning the worst of the bumps off, but that may need to wait until my budget recovers.
The first step was disassembly; I've got the whole thing (except the motor) down to individual parts and am currently cleaning it off and stripping the paint. For the time being, I'm coating the bare metal lightly with oil to prevent it rusting and hope to have it coated with primer before winter comes and ends the painting season.
Accessory-wise there is a steady rest which looks original - plain fingers with no rollers - a faceplate, a few dead centers, and an old three-jaw chuck. I'm still evaluating the motor, which does run alright, but I'm considering swapping in something with a bit more power to support heavier cuts.
The lantern-type tool post is a beauty, but I really want to pop an Aloris-style QCTP on there. I know it'll look really horrid and jarring but the convenience is hard to argue with.
I'd be curious to know folks' thoughts on paint for a lathe which is expected to see moderate use. At the moment I've got some Tremclad 'Rust Paint' primer for the base coat but I'm still considering whether to go for POR-15 engine enamel paint (about which I have heard many good things from Quinn at Blondihacks) or to just get a basic metal paint from my local hardware store.
In the event that I do get everything properly cleaned/scrubbed/stripped/primed
and painted before winter begins, the next step will be ordering a few replacement parts. I found someone on eBay who offers rebuilding kits with the full set of felt wicks, wipers, and pads as well as replacement belting, which is definitely a must. Then, it'll be on to reassembly!
Anyways, I don't have a huge amount of shop time so it this may be kind of slow to update but I thought people might find it somewhat interesting and I will post updates and photos when I can.
Cheers,
Nolan
