AHHH! (Light bulb over head flashing)
Got it.
And love it.
For $15 - its a done deal for first round experiment at minimum.
Thanks.
If joystick is a failure - I can toy around with other means of engaging - but this will get me out of the gate.
Having slept on it - using your external box idea as a starting point would likely be the quickest simplest.
Once I have a set up I like - I can refine its placement and install in a custom face plate .
So we now have a plan for spindle movement up down.
As for motor power - yesterday - received my VFD.
Fish out of water on this - but think I get the gist.
Posting below with request for input - to avoid shutting down neighborhood with blackout due to user error.
So obviously - three wires run form plug to VFD at R/S/T connections, but not sure which correspond to which on the plug?
Then 3 wires run from VFD to motor - motor has black red green currently. VFD is labeled with U/V/W.
Finally - VFD has a "earth" terminal, 1E, but I'm not sure how this would come in to play at all for my set up?
Think we might be able to test the motor today with a little help - and a little luck...
Thanks!
-CM
Diagram - mine is the bottom model.
Plug I will get from Lowes
