- Feb 8, 2014
- 11,187
I chose the spot for my controls to reflect my 50+ years of muscle memory of reaching up and to the left to control the spindle switch with my left hand. The spindle switch on almost all BP type machines is on the left of the belt housing. If you don't have that muscle memory then anywhere convenient is acceptable.
Your switch configuration depends on how you program the inputs on the VFD. On/Off/On would be OK. There are normally at least a half dozen switching options that can be programmed. In my case the For/Rev programmed/wired so a closed contact is reverse and that same contact open is forward. Start is a momentary contact closure. The common is wired through the E-stop switch so when pressed, the run command is open.
In the case of a For/Off/Rev switch you would need two NO contact blocks on the switch. You would want that twist release E-stop button in any case.
The Automation Direct out-of-stock items can be substituted with other items that are in stock. <insert nasty comment about current supply chain conditions here > Most of them you can mix parts between switches of the same series. I normally keep a few extra contact blocks around, you can buy them in packs of 5. You can also buy the bodies and operators separately to make up your own switches.
I would wire the VFD power into the cabinet main disconnect just as it is now, except use 2 wires (+ ground) rather than 3 as it is now. Mine is actually wired straight to a breaker in my shop main panel, I never turn it off.
You could always make a spacer for the front mounted location to give the depth needed, I think you need around 35mm behind the panel
With the mechanical variable speed you could just program the VFD to default to 60Hz and do all the speed adjustment with the mechanical adjustment. That method has worked for many years.
