- May 2, 2021
- 330
Had misunderstood the prior post about using my power supply to test - thought you meant with joy stick.You are not going to connect the joystick between the power supply and the controller. The joystick terminals would connect in place of the switch furnished with the controller. We'll get to those connections when you have a controller in your hand.
Was amazed by your electrical engineering prowess - that would combine my power supply with the joy stick and reverse polarities!
Alas - joy stick will be replacement for forward backward switch on power supply I've ordered...
Noted.
Rest of the description is clear.
Thank you.
Will report back with results.
