Hmm - may have over simplified that one in my mind.
Thanks for the research and suggestions.
Universal Pendant seems viable.
Question: Does the dial act as a kind of rheostat - speeding up the motor in either direction depending on clockwise or counter clockwise twist of dial?
That said - I really liked the idea of a foot pedal with variable speed control - for moving the servos.
Don't want to throw in the towel quite yet on that - think it would be super functional.
Foot pedal speed control, with sprung joy stick sending it left/right or up down.
Editors note - I have foot pedals on everything in my house - including the kitchen sink - literally...
Can we beat that one up a bit more - and perhaps you can educate me on why it's bone headed?
My electronics naivety will be on full display...
I see three types of foot pedals.
Some pics and specs below.
1. AC type used with grinders. Juts plug in between tool and 110v wall plug
2. Welding type. Assume AC. Much heavier duty. 7 pin DIN connector. Perhaps that means it has 7 steps?
3. AC/DC conversion type. Plug in to 110AC - output DC volts
I was initially thinking an AC type feeding a converter.
Now I am thinking that perhaps the issue is - a converter wont work if it is fed less than it's 110V.
This DC one appears to be viable - but perhaps its 4amps is too little/ would hurt my motors?
https://www.amazon.com/Control-Vari...ble+speed+foot+pedal+dc&qid=1622817340&sr=8-6
A more out there idea would be to combine my existing gynormo original servo AC/DC converters from my electronics box with one of the heavier duty AC foot pedals from the welding world?
Did the DC voltage put out from these converters get increased and decreased by a controller AFTER it came out of the converters as opposed to the converters RECEIVING variable AC current going in?
I'm wild guessing here - but throwing it out to see what I learn/ checking all the corners of the envelope.
AC to DC converting foot pedal from like above. Specs at very bottom of these pictures cut and pasted from Amazon.
Light weight AC for grinder
Specs of what it powers:
Welding type foot pedal - appears much more heavy duty - suspect much higher average - uses DIN plug
Specs of AC to DC foot Foredom foot pedal (first pic)
(Foot operated speed control comes in a heavy, cast iron metal housing and the extra weight provides added stability and control. It features the same durable, solid state electronics as the C.TXR. The ergonomics allow precise and reliable speed control with your foot. C.SXR-1 has special electronics that converts AC current from an electrical outlet to DC current- the type required by the motor. It also has a special plug that fits the motor's shielded plug. For use with 115 Volt M.TX, M.TXB, M.TXH, M.LX, M.LXB, M.LXH and M.LXBH motors. 7” long, 5” wide, 2-1/2” high, packaged wt-6 lb/2.7 kg, 4 Amps, 60 Hz It is interchangeable with Foredom's C.TXR-1 and C.EMX-1 controls.)
