- Dec 9, 2021
- 734
It sounds like you want to use "Micro" size bells. I use them for 3/8" cable. "Mini" size bells work well for 1/2" cable. I have Mini size sliders on my bulldozer winch.
I can't imagine trying to use chain chokers. One advantage of cable chokers is that you can push them under the log because of the inherent stiffness of the cable. You may have to take a stick or limb and dig a small hole for the cable nub to get under a log that is up tight against the ground. A chain has to be pulled under the log, there is no push!
There is a lot of logging done in my area. Most has gone to machine harvesting and "shovel logging" using hydraulic log loaders to bunch and shuttle the logs from the stump to the landing. Because of this, there are lots of used chokers, bells, sliders, etc. available on the used market for reasonable prices. If you have places nearby that cater to the logging industry, check them out for hardware.
Edit to add: I use 5/8" main line, four sliders, and 1/2" chokers with Mini bells on the winchline of my small crawler dozer. Its winch is rated for 30,000 lbs. pull with a bare drum, which is half again more than the weight of the dozer! For your 1/2" mainline, 3/8" chokers would work well.
