These current spike noises from the VFD look like broad band noise, as the edge is fast, so the Fourier series has lots of high frequency harmonics, and in your case in the wi-fi range. I didn't see if you have a DSL, or Cable modem as your internet source. The problem with those Pi filters used in commercial computers, they require a very good ground connection. You don't have that if a ground wire is your return path to earth. In a home, it is a long path, that looks like an antenna. These EMI filters are there to pass the FCC emissions part 15 tests. Your VFD upset may be from noise on the ground, injected via the VFD power connection, as the VFD will have an EMI filter needed to pass emissions testing requirements from CE or FCC compliance standards. Your photo of the EMI (apple Macintosh box) shows you having the ground with a ferrite filter. Did you do just a test on the ground path before this final packaging of the filter?I suspect that the better final results were related to the capacitors the filtered socket has: 1 capacitor 0.1 uF and 2 caps 2200pF
What puzzles me is the fact that all filters I had tested initialy were giving very poor results. To be honest I was expecting to solve the problem once for good using the filtre ftom the UPS unit!
It seems that the combination of the 3 ferrite toroids was just right for the high frequencies produced by the VFD.
Thank you for the kind words brino! I' m glad you liked it.Petros,
Thanks for the additional information.
I appreciate your logical, systematic approach to problem solving.
I really enjoyed this thread!
Thanks again,
-brino
The problem proved to be not to the output of the VFD, where usually the wires act as aerials and propagate the noise, but the noise signal was travelling "backwards" through the power line to the rest of the house causing interference problems to other appliances.They recommend using shielded cable going from the VFD to the motor, and the shield should be grounded, for obvious reasons.
Yes it works like a charm! No problems when I use the VFD!Does the Internet at your home work now? It's funny: those commercial filters look like they contain toroids. Maybe they were too wimpy?
Thanks for your effort of documenting the solution that worked here. I've always been curious if a isolation transformer on the input side of the VFD would work to alleviate these kind of interference problems? The isolation transformer would prevent a current path between the secondary and primary, and any current that wanted to get back up the supply wires from the VFD would be faced with the huge inductive reactance of the transformer. Would this work? I have seen reference to this being used in industrial settings too. I would post them but can't right now as a new member.Yes it works like a charm! No problems when I use the VFD!
