- Dec 22, 2012
- 328
Thanks Ron. Yeah, I might have said a bad word or three.
Got back at it today. Set the little flycutter for Ø 1.125" and cut a shallow circle in position for the buffer tube threading, then drilled the center and plunge milled near the circle's perimeter.
Switched back to the flycutter to take the bore to its final diameter. Pretty pleased with the finish the little flycutter delivers. I used the same flycutter to cut the chamfer on the edge of the bore. Also used it to cut the straight chamfer at the top rear of the buffer tube ring (far left in the pic). Located and center drilled the buffer tube key, then finished with a .500" endmill.
New setup got the breakdown pin detent drilled, (without breaking the bit off this time!), and milled the slot through the pin lug. This was done with a Ø .375" endmill, then opened up to .500" width.
Finished up for the day by milling and drilling the pistol grip boss. Now if I could just find that 1/4" fine thread tap I set aside for the grip.
Tom
Tom
