- Jan 10, 2014
- 200
Not sure if this is the right forum for this, but here goes.
I have this old air compressor that someone gave me (30 gal, 200 psi). The tank is rusty on the outside and sounds like it is half full of rust so I have decided it is too risky to pressurize.
I found a replacement tank online at ecompressedair.com (ASME specs, outfit looks pretty reputable, price is decent). Have any of yall ever done business with them before?
I am also wondering about the ports. From the pics all of the ports are open on the new tanks, and you have to add your valves, plugs and whatnot. Should anything be put on the threads for the stuff you are screwing into the ports? Loctite or anti-seize or anything? I was just going to use rated valves from Northern Tool and steel plugs from the hardware store to stop up the ports I am not going to use.
I'm also wondering about pressure. The tank I'm looking at says 200 psi and the compressor that is donating the pump and motor has a tag that says max working pressure is 200 psi. Max working pressure and max pressure is the same thing, yeah?
Is there anything I'm overlooking or should be aware of?
Thanks for yall's input, and sorry if this is in the wrong forum.
Morgan
PS I am also open to suggestions of things I could do with the old horizontal tank besides scrap it. I already have a grill, though.
Morgan
