- Oct 31, 2011
- 5
The part pictured is an ABS foosball man. I'll be going to a mold fabricator to make a mold for a part very similar to this (picture). The only problem is, when they take the ABS part out of the mold, sometimes there can be a small difference in the dimensions. The dimension that is critical is the big hole in the middle. It needs to be exactly .680. Plus or minus .002.
The part in the picture is one I bought from the worlds biggest foosball company, and they have screwed this up. . The center hole is .008 too big and the piece is no good. I really don't want to make that mistake, so I was talking with a friend and he suggested having the part molded with the center hole made a little small, and I finish the hole with a ream, or drill bit. I've been reading about machining ABS and it looks like there are specialty drill bits for plastic, but I'm more interested in using a ream. There are more size options, and would the hole be more precise?
So my question is, could I have them mold the piece with the middle hole .670 and use a finish ream to cut the hole to .680? Would that be too much material to remove with a ream, and would a regular ream (designed for cutting steel) work with the ABS?
