• Welcome back Guest! Did you know you can mentor other members here at H-M? If not, please check out our Relaunch of Hobby Machinist Mentoring Program!
  • In order for the Member Map to work properly, you must allow Google services AND Hobby Machinist to know your location. These settings are found in your browser of choice and in your Hobby Machinist profile.
Winner A Dividing Head By Wayne
Status
Not open for further replies.
I came home this evening and wanted to see if there was any responses to my post, thank you Fomogo Mike for your positive response
I am quite taken aback by the encouragement I have received in this project. Mark I had never heard of MacGyver and looked him up on wiki
I must have laughed for 10 minutes non stop!! by some coincidence I always carry a genuine swiss
army knife, but fortunately don't seem to find myself in the positions he does. Please do not change this thread to MacGyver saves the world by making a dividing head. lol
I found this guy, what to use it for???
Sent from my XT1093 using Tapatalk
Not much for cfm as a compressor. Make an ic hit miss. Machine a head, single lobe cam for valves and spark.
Nice work wayne. I have plans to use a dividing head. Not much material to make it yet.
Jack
Sent from my SGH-I337M using Tapatalk
Hi Jdj, nice little quincy x2 compressor, if you ever get that going and anyone needs their tyres pumping up they will know where to come,
nice little project. Hi Atlas ten, I don't have a dividing head yet, finished off the facing tonight and I have 4 nice pieces of metal, tomorrow night I have to
bore the pilot holes for the side plates then make a boring tool for the trunions, I am beginning to wish I had attempting these first and turned the barrel to suit
but we shall see how it goes.
Do you have any idea when my X2 was manufactured?
Sorry JDJ I don't know the year. Iam sure you could find what you want to know by searching the net, the serial no.
on the casting may help.
I have searched, even contacted Quincy and they said they are working on finding out a date. My x2 doesn't have the serial plate like later models have.
I pondered how I was going to cut the pilot holes in the side plates and the only solution the made a sizable hole was to use the cnc
capability of my mill. I was reluctant to do this because of the backlash in the lead screws. I messed about trying to measure the backlash
and enabled the backlash compensation in the software I have done this before but only made a bit of difference. I decided to go 5mm under
size to give me a bit of leeway but not too much to bore out later. If all went wrong I could make another plate and do it again.
I wrote the code for a continuous spiral into the work 1mm every revolution
with a 8mm cutter did a dry run, clocked and clamped a plate onto the mill, and with my heart in my mouth pressed run.
I watched go round and all seemed well I let it go round once to scribe the circle then wile it was running gauged the approx diameter
with my vernier with a steady feed rate it started to cut into the plate after the cut got deeper and full of cuttings I tried to keep the cut clear with a neodymium
magnet I salvaged from a hard drive which worked ok but got stuck to the cutter a couple of times, strong magnets, all went well and the piece dropped out.
The hole is not bad, 0.8mm over size but only 0.2mm out of round. I did a video but I cannot upload it, it is just the cutter going round for the last cut and the center dropping out. One more to do, then my intention is to clamp the 2 side plates together on the mill and bore the trunion hole through them both at the same time with a boring tool of some description that I don't yet have.
Status
