- Dec 18, 2022
- 2,391
I Have a PM Dividing head BS-2, yes it can be turned while you mill on the piece in it. The BS-2 is setup with that being one of the intentions, it can be geared to the mill table for cutting helix, rifling buttons, worm gears etc... It is a very nice unit but if your not looking to connect it to the table I would suggest the BS-0 or 1.I have been looking at the dividing heads that Precision Matthews sells, and thought of a question that I couldn't find an answer to.
Can you mill a part that's chucked up in the dividing head, while you turn it? Or can you only machine while it is locked in and stationary? Take the muzzle brake below, can those ports be machined by inserting the end mill then turning the crank to the other side then withdrawing the end mill? Yes, I know there are a lot of other variables to address with rigidity, and setups. This is just to give context to the question.
Just an example photo.
I could also just use my rotary table and then rotate the head of the mill to achieve the desired angle or create an angled setup with the rotary table. I'm just trying to figure practical and likely uses of the dividing head.
